AltonToth
- Vancouverish, BC, Canada
So, I saw these nifty looking devices at Home Depot, and immediately fell in love with them. The Triples receptacles, and the single button light switches...how could you NOT love these things? (especially in an office, where more plugs are always welcome) However...one problem, which I'm hoping I can find a work around, if not a solution for, here. I've already been in contact with Leviton's product engineers, and they have confirmed for me what I'm about to describe.
I bought a mechanical switch in the Acenti style. It's nice, good solid feel, and best of all, it has an indicator light that comes on when the light is off (so you can find the switch in the dark). However, upon installation, I discovered something interesting. I use CFL's throughout my house, and as soon as you shut the light off, these things started a private rave in the office (flicking the CFL's on and off). A little chat with the PE's confirmed what I thought: that the trace amount of current from the LED indicator was just enough to cause the CFL to try and fire up. Luckily, this switch is controlling a ceiling fan, so as long as the ceiling fan is on, it won't strobe the CFL when turned off.
They recommended to me the use of an electronic switch (same device apparently, but requires a neutral connection as well). Here's where the problem occurs. I don't have a neutral connection available to me in the switch box. Instead of using the non-existent neutral, am I safe/ok to use my ground as a dump for that tiny bit of current? And if not, does anyone have any other suggestions on how I might make this happen? (short of digging through my walls to run neutral conductors to every switch I want to convert, or going back to incandescent).
Cheers (and sorry for the long winded post)
