barefootbryan2335
- Atlantic Beach, Duval, Florida
We are going to have to wire practicals on our new stage for our nest show. In the last city we were located we were told by the inspector that we had to remove all extension cords from the theater space. No cords of any description were allowed.
I understand the NEC code says you cannot use an extension cords in a permanent situation. The inspector defined permanent to be anything in place over 24 hours.
In our new space (different jurisdiction) we need to be able to wire practicals. I have tried to look into it and cannot find an online authority to get an opinion. I have reread the NEC 520 code. It seems to me you can use cords (SOOW or SJOOW). How should I wire needed onstage receptacles or switches wire with cord to portable shoe-box dimmers or a 20 amp distribution point. I want to get this correct so that I do not get flagged by an inspector in our new space. We will have this installed under 30 days for a production run. If cable can be used, what type is alright to use, SOOW or SJOOW?
