MCA (Minimum Circuit Ampacity) is a value used to determine the minimum wire size needed to safely carry current for a motor or electrical system, while FLA (Full Load Amps) is the rated current a motor draws at its full load operating condition. MCA is typically 125% of the FLA.
With FLA, you can then calculate VA
