green2012
- highland park, il
I have a three phase 480/277 600amp panel. There is a 200 amp 3 phase breaker feeding a lighting panel. When first installed they were using highbays and such, but they recently did an upgrade to thier lighting and the owner insists that he is using half the power he was to light his shop. We are considering changing the 200 amp breaker for a 100 amp for several reasons and need to perform a load calculation to see if he is under 100 amps. I am used to working residential and havent worked in a 3 phase system for a while. My guess would be to do it the exact same way. Put a amp probe over each phase and see what the draw is. If each of the 3 legs read under 100 amps we are good to downgrade the breaker? Am I missing anything? Is there a better or more efficient way? What would you guys do?
