xara
- minneapolis, mn
I calculated the total load for a dwelling to be 20133 VA which equals 83 amps. Does this mean that the main breaker must be 100 amps?
It does need to have a main disconnecting means. The easiest and most common way to achieve that is to put a main breaker in the service panel.But, depending on type of service & local requirements, may not need main (although often nice to have).
What I was referring to was the 6 handle rule (unless that has been changed) .
Main is an ambiguous term when discussing Code. Suggest using the term service disconnecting means whenever possible to add clarity to your posts.It has not changed.
