kwired
Electron manager
- NE Nebraska
- EC
Fourth factor is moisture content of the corn and can effect shelled corn or ground/milled corn.Interesting geometric tidbit: Some people feel intuitively that smaller objects should pack better. But in fact if the shape is unchanged objects of any uniform size will have the same packing fraction (ratio of occupied space to total space.)
Milled corn can have a higher density than shelled corn for three reasons.
1. The shape of milled corn particles allows tighter packing than shelled corn particles.
2. Milled corn contains a mixture of particle sizes, allowing the smaller ones to fit into the voids between the larger pieces.
3. Milled cord particles are softer and so can be packed tighter because the touching parts can compress to allow closer packing.
Some processes may have a desired moisture level and it won't vary much in the supply, some processes it could vary.
