kwired
Electron manager
- NE Nebraska
- EC
Could set up controls that monitor the water heater and isolate the AC unit when WH is heating so they would never run at same time.If an electric water heater, they may be able to run with it switched to 120 volts (if their usage pattern permits). I did that to ours when I had to temporarily move it for a month. Never ran out of hot water, even though it took 4 times as long to heat.
But then another question about OP is why is there two ranges, dryers, etc? and are they actually used all at one time.
Seen many cases with a 100 amp main and single range, single dryer, single WH, and AC and no problems holding that 100 amp main, but start adding additional ranges, dryers etc. that do get used often and you might be pushing it.
