electricalperson
- massachusetts
i used my seesnake and i might of located the cable at the top of the wall but not sure im probably going back tommorw
electricalperson said:anybody have any tips for locating buried boxes? a homeowner decided to move a switch i roughed in a few months ago and i have no idea where he put it since it was buried by sheetrockers. my bag of tricks includes feeling the wall for bumps with my hand, using a 2x4 to see uneven spots, using a circuit tracer, and last but not least using a screwdriver to make holes when all else fails.
next time im going to use spraypaint on the floor under my switch and receptacle boxes and put an R for receptacle and S for switch. maybe ill buy a digital camera...
Since this is a garage, these are more than likely insulated stud bays. That would pretty much mean exploring the cavity pretty thoroughly with the scope. No peeking up or down the whole bay, in this case.Rich R said:Make a small hole at bottom of each stud bay and use camera to look up
ohm said:I first measure for voltage where the wire should be comming from. If live, kill it then hook up a toner, Then try tracking your wire along the sheetrock. I've been able to follow wire to burried boxes many feet away with my Harris Toner.
That sounds like Sheriff Pusser 'searching' a car in Walking Tall.sparky723 said:If he does'nt find them for you, Take the largest EMT bender you can freely swing and start wailing on the wall where you 'think' the boxes SHOULD be.
Guess what? we found them.
If the box was moved by an amateur it probably wasn't stapled. I would try attaching a pull string and pull the wire out for inspection.alfiesauce said:Even if you find the box, what are you going to do about the splice?
I don't like it!celtic said:
It's legal, right?
What are you, an inspector?!SEO said:I don't like it!
celtic said:
It's legal, right?
ohm said:If the box was moved by an amateur it probably wasn't stapled. I would try attaching a pull string and pull the wire out for inspection.
alfiesauce said:It is legal, but I sure wouldn't trust some homeowner to do it up properly. Especially if he can't even mount a box...
alfiesauce said:...
Maybe he could cut in a receptacle box below the switch for a proper splice.
