JoeDunn
- Central NJ
Hi Everyone!
I'm new here and my question is:
When installing 2-5/8"x8' ground rods for a detached garage Sub-Panel ... The rods will be driven in to the ground 6" below grade and spaced 8' on center. Assuming that the roof has a 12' overhang with a gutter system draining to the rear of the garage and the rods will be install on the same side as the gutter system ... where in relation to the side of the garage/roof overhang should the rods be installed?
One co-worker says it should set beyond the roof overhand where the grade is slightly higher and less water pools(dry soil provides better grounding). The other persons states it should approx 6"-8" from the garage and under the overhang where the water pools slightly(wet soil provides better grounding).
Also, would it be ok to attached the single ground conductor (#8AWG) from the ground rods to the outside of the Schedule 80 PVC using plastic ties(this conduit runs back to the Main Panel at the house and has 4-#6's H-H-N-G) that runs up the side of the gargae to the Sub-Panel?
Thanks for your input!
Joe
Joe
