david
- Pennsylvania
Re: Location of Service Main Disconnect
David, I think you are reading too much into the defintion of service and attributing too much wiring and equipment to it
bphgravity
Maybe, but it has already been well established that service conductors upon entering a building must land in a service disconnect, so if your right then there is no need for this rule in the book. If you are right then there is no way to supply one buildings service through another building.
?230.3 is prohibiting the service entrance conductors from passing through a separate building or structure before it lands at the meter enclosure or disconnect at the building it will serve?
If the rule was addressing service entrance conductors than it should have said service entrance conductors instead, it says service conductors which I have already defined
I never said I agree with the rule all I know is the definitions as I gave them are correct. When I apply the definitions to this rule I still conclude as I said through out this thread.
[ March 13, 2003, 01:07 AM: Message edited by: david ]
bphgravity
