kwired
Electron manager
- NE Nebraska
- EC
I think you missed the point, water gets inside - even a "raintight" fitting, hence the reason the interior of outside raceways is a wet location.Why would a Myers hub be a problem? If you install it correctly! Your point is mute!
Sent from my SM-T350 using Tapatalk
Myers hub with GRC not fully threaded into it is going to leak more then one that is fully threaded into it. But both still are subject to condensation forming within and there really is no point of trying to completely seal each and every fitting on any outside raceway system or even inside in an environment prone to condensing.
