royp
- Loxahatchee, FL USA
We have a building with a circuit breaker panel on the exterior
of the building. They are in a high crime area. The owner wants to know if
they are permitted to put a lock on the disconnect switch to prevent it from
being turned off by vandals. We are looking for the code citation that
either prohibits or permits the disconnect to be locked. On the meter socket
can FPL has a big lock. The fire department has a policy does not remove
meters so the lock on the meter can is not an issue. They only will throw the main circuit disconnect.
It appears that the circuit breaker panel enclosures have places for a lock to be installed. But can't find either a prohibition or permission to install a lock on a disconnect.
