Dale001289
- Georgia
I’m trying to determine if the Client specification needs to be revised. They want the MCP settings from 700% to 1300% (460V induction motors) and motor locked rotor must not exceed code G per NEC T430.7(B). Is this realistic? Would it be better to have the range up 1700% (per NEC exception) in case they have a Design B or E high efficiency motor? Is that even possible for Code G?
We’re focusing on 15HP motors (up to 100Hp).
Is it likely the MCP will trip with Code G when set at its maximum setting of only 1300%?
