hi i need some help, ideas & or pictures on wiring a log home. the home is 2100 sf real logs & is already built, the builder drilled chases as they were stacking and the home is also chinked (sp). i told the owner it would be t&m
this is my first log home, & i unsure whether to run or take on this project.
first question how do you make the switch & plug box's look good on a round log ( i figured floor box's for most ext walls ) but i still have the switches?
second the ceiling has exposed logs & 1x6 tg cedar the owner want ceiling fans mounted to the logs & surface mount light everwhere else, how do you mount a fan box to a round log ( and have it look good),how do you hide your wires in the ceiling, & how many holes ( if any) can i drill or router in these ceiling logs, there is no way to get around them,
i'm going to go look at the home again this week, crawl in the crawl space & look for chases, run fishtape in chases to find out where they go, etc.
thank for any input
thank for any input
