I've had an individual approach me about wiring some log cabins. I've never been involved in a log cabin build, but could see it quickly becoming a headache if the builder is in a rush. These are going to be slab on grade probably no more than 1,000 sq ft a piece. Just wondering if anyone had any pointers on how to run wire. From the little bit of research I've done it seems like lots of notching in the sill plate and then drilling through each course till you get where your going. I saw someone mention if the logs are being chinked they would just run wires between the logs and then the wires get covered with the chinking. Is that legitimate? My first thought was running PVC through the slab and stubbing up into the walls and having them set the courses over the conduit. I havnt seen anyone trying anything like that and i suppose getting the boxes in may turn into a nightmare. No matter how you shake it down it seems like some solid planning will definitely result in less frustration and a better finished project. Any suggestions are appreciated!
