- Placerville, CA, USA
- Retired PV System Designer
Very good idea if the evaporation of the water does not leave a residue on the coil or fins.
Tapatalk!
Tapatalk!
I definitely have got a lot of good info. here on what to look at and I think I will be able to save them some money. How much, who knows. I will look into if they are using hot gas or electric defrost.Does the refrigeration equipment use electric defrost or hot gas defrost? And could it be retrofitted to hot gas defrost? Big money saver right there. Walmart only uses electric defrost, which I never understood.
I can see that making great sense on large chillers working at partial loads.
The stores I work use many small compressors of different sizes on a central common manifold or header. The control systems use the most efficient combination of compressors to maintain the pressure set point. It is a constantly changing volume of gas they need to pump due to different cases going into cooling mode.
They have tried VFDs but they never seem to work out, I always see them bypassed.
In the three or four chains I work in hot gas is being phased out for electric defrost.
According to the refrigeration contractors that is due to the fact hot gas defrost often results in leaks. The constant expansion and contraction of the copper lines when you switch which line is hot result in wearing of the copper against things.
Never knew that! Common problem I have heard with hot defrost is maintaining adequate condenser/evaporator temperatures during the winter when the units go into defrost. (think pulling heat from -5) Another thing I have heard is its substantially more complicated. Doesn't it also require a 3rd line going to the cases?
FWIW I was just repeating what other contractors have told me, that may be true or just myth.
The stores that I work in that use reverse gas do not have a third line going to the case but at the refrigeration rack in the mechanical room there is a lot more plumbing, valves and controls.
Also each case needs its own pair of lines from the rack to the case. On the other hand with electric defrost they can run a large set of refrigerant lines out and put control valves at each case.
Id say true. Its just a guess for me but it makes a lot of sense.
IME in smaller stores a lot of display fridges and freezers are self contained with the compressor and condenser built in to the cabinet as in a domestic appliance. If this is the case, it is most important to ensure that the appliance is properly ventilated and that the condenser is kept clean. All too often such appliances are tight against a wall when the suppliers recomends say 6 inches clearance, and are never cleaned.
Many suppliers of beer, soft drinks, and ice cream offer free fridges and freezers to display and sell their product, these are often of very poor efficiency even if fairly new.
Finally ensure that lighting is turned off when not needed ! this may seem elementary but a suprising number of shops light toilets, cleaners cupboards or storage rooms 24/7.
That was my feeling as well.
Figure 2-4 defrost cycles per day and after a few years that could be a lot of wear.
I was just trying to be clear I had not seen it first hand.![]()
Many suppliers of beer, soft drinks, and ice cream offer free fridges and freezers to display and sell their product, these are often of very poor efficiency even if fairly new. If these appliances are cord and plug connected, then use of a plug in, consumer grade power and energy monitor could prove interesting.
