lgmagone
- Orlando, FL
I am trying to design an electrical system a client that would like to have a driveway gate at the edge of his propety. The client's property is large and the gate will be located approximately 1000' away from the house. The local electric company has said it would be expensive to install a second meter because an additional transformer would be necessary plus the additional cost of metering.
What is the easiest way to run power from the house to the driveway? I calculated (at 3% voltage drop) that a 3/0 conductor would have to be run to provide 20 amps at 120V at the gate location. This would be a very expensive wire!
I could run 208V to the driveway gate as a subpanel and then drop 120V from the subpanel. This would allow me to use 1/0 wire for a 3% voltage drop, still expensive.
Are there any other solutions that may cost less? I don't have a lot of familarity with running power over long distances. I'm thinking I specify two transformers and increase the voltage at the house and drop it back down at the gate, but again, this may get expensive depending on the cost of transformers.
Thanks,
L. Greg Magone, EIT
Thanks,
L. Greg Magone, EIT
