 - Massachusetts
If we need reducing washers, must they be made of PVC, too? :grin:
For what it's worth the bell end on 3/4" PVC fits over the bell end of 1/2" PVC very nicely.
Arlington makes a perfect product for this. I've used them for years with great success.
http://www.arlcatalog.com/Rigid/Pipe Hangers.htm
Don't drive the screws in so tight ..... seriously.![]()
I am just afraid of possibility of a leaking roof. But I guess the clear silicone we use will do a good job? I always thought the product used to prevent leaks on roof was a substance like black tar, but we are using this silicone that is as clear as water.
Yes, too hokey. Use 2-hole PVC straps.
2 hole straps aren't strong enough, plus they don't mount to strut. What I have is an existing strut rack holding a group of conduits about 7-8' off the ground in the free air. This is in a barn where high humidity and vibration are a problem on this strut rack. The existing conduit is emt, but I'm trying to get away from that due to rust. Using strut straps with small chunks of pvc means I know I'll never have a strap failure like the weak pvc straps. I guess I'll just go ahead with it. I thought maybe somebody else might have done it this way before...
Personally, it may look a little funny but I know it'll hold and function as it should. That means more than asthetics in this particular situation.
