zcanyonboltz
- denver
Electricamagician
I doubt there were electrical conduits before string was invented.
Wow pretty interesting stuff here! I just meant how'd they get the string through the conduit.
I would guess that you would loosely lay out the conduits, and send the string through every 10 feet of conduit, stick-by-stick. Maybe by tying a knot at one end, and dropping it through. Then you'd drop the conduits in the trench with the string inside, apply the glue, and put them together.
You revived an old thread by posting a new topic within it. You really should start a new thread with your new topic.
Still is to some people lolThey must have been magic.
Just put wire lube on the string if you can't wait?
It only took me one of those.I can tell you from experience that installing string in conduit that is freshly glued, especially a long run with a lot of glue joints will ultimately result in a string that ends up glued in at several joints. Of course, this isn't discovered until you come back later when the glue is good and dried and you try to get the pull string out to get the rope/cable in. In our instance, it was a 1000' run. That was a lot of glue joints, it wasn't pretty.
Now I give it some time before I install string in long runs of conduit.
We pulled in some underground today about a 250 yard underground pull. I was wondering how they used to get the wire through the pipe before shop vacs and pull string were invented? Push a fish tape that far? Also what'd they do before tuggers?
Way back in the good old days you would not have been dealing with PVC conduit for underground it would have been rigid. PVC is post world war twice.
In the early days conduit was ran by plumbers and I'm pretty sure they would not have helped out the sparkies by pulling in a string.
It's just a guess but since compressed air and string were around before conduit (electrical type) I doubt it took very long for them to figure out how to get a rope in the conduit.
Before tuggers there was a contest called a tug-of-wire and I wonder how that got started.
Waaaayy back they would have needed carpenters, since the conduit was made from wood:In the early days conduit was ran by plumbers and I'm pretty sure they would not have helped out the sparkies by pulling in a string.
