Freshlife706
- Augusta ga
- Maintenance technician
doing a lab for my plc class and reaching out for help to try and understand.
Ignore the actual value of the thumbwheel shown in rung one.so would the variable value just have to be 5 to be equal to the constant value?
i was thinking that variable 2 would have something to do with the BCD but 2 = 0010 and 5= 0101
I'm just reaching out because the teacher that i have has no idea how to explain this to my class and gets nowhere, the book that we have does not explain this process at all.
Not according to the logic provided which has three rungs containing an Equal compare, a Less Than compare and a Greater Than compare with corresponding colored lights.Greater than 1 but less than 2
so on rung 3, does the variable value just have to equal to the constant value to make the red pilot light to turn on?Not according to the logic provided which has three rungs containing an Equal compare, a Less Than compare and a Greater Than compare with corresponding colored lights.
Yes.so on rung 3, does the variable value just have to equal to the constant value to make the red pilot light to turn on?
That is not part of the OP question, which can be answered solely be looking at rung #3.does the class understand how to read binary?
if not, there's the problem
we are only on chapter 3 of the textbook and it doesnt really talk about reading it yet, just how to convert from binary to hex from octal to deciaml and so on.does the class understand how to read binary?
if not, there's there's the problem
okay well that makes alot of sense soThat is not part of the OP question, which can be answered solely be looking at rung #3.
Thee program might not even be running, so none of the rungs may be displaying real vaules at all.
OP followed up and stated that the instructor could not this to the class so there is a fundamental miscommunication or misunderstanding. That prompted my response.That is not part of the OP question, which can be answered solely be looking at rung #3.
if one can't read a BCD, one can't understand what an FRD is doing. It might as well be converting Sanskrit to an integer.the FRD instruction just converts a binary input coded in BCD to a standard integer.
one does not need to understand bcd to understand that the result is a standard DINT.if one can't read a BCD, one can't understand what an FRD is doing. It might as well be converting Sanskrit to an integer.
And the OP question was dealing with the value needed in rung 3 for the red light, so it must have been about the Compare function.if one can't read a BCD, one can't understand what an FRD is doing. It might as well be converting Sanskrit to an integer.
