Thanks Gentlemen, is it a law anywhere else outside of osha?
I believe the article/testimony above mentioned that some states administer OSHA themselves as opposed to the Federal Government.
I don't know if these states could also modify the laws or not?
Then there are state laws, county laws, city laws, some metro areas "regional laws", and then "administrative rules" for any of these.
I suppose any of these fiefdoms could enact any law they wanted?
If you can search these various laws for your area online, search for...
lockout
"lock out"
tagout
"tag out"
As to searching, you need to be able to search the entire code at one time, not just one section of a code. So if they have pdf files - one saying entire code, then others listing specific sections, use the entire code pdf. Others have a search where you can select what you want to search.
So far as searching for a phrase, in some cases you can search for a phrase using quotes like:
"tag out". In other cases you would need to enter the words into an advanced search box labeled Exact Phrase or Exact Wording.
Then another trick is to use google.com advanced search and you can list a specific web site to search. Then it will only search within that website. To use this go to google.com and click on Advanced Search on the right of the search box.
