looking into purchasing a piece of equipment with 40hp 480 motor transformer advice
TEXAS
MANUFACTURING
we are looking at purchasing a large liquid ring vacuum pump 40hp 480v for our cnc router we currently have two pumps that are in total about 30hp witch we will be replacing, we are In a rural are our three phase that we have now is a high leg correct me if I'm wrong think they are calling an open delta 208 3 phase, we have 2 transformer's on the pole. would it be possible to use a stepup transformer after looking at some calculations online looks like I would need about a 35-40kva transformer would this work?
It would behoove you to work with a competent electrician.
It's possible that the equipment you are asking about could be reconfigured to work on your existing system.
There are many variables that can have a bearing on sizing the transformer if needed.
Any advice we might give here might guide you in the wrong direction.
