lady sparks lover
What is a loop transformer and when do I use it?
Lady
Lady
don_resqcapt19 said:Lady,
Are you thinking about a loop feed system? The primary power cables loop in and out of a number of transformers. The system is noramlly operated with the loop open at one point and the open set of cables "parked" of terminals in the transformer primary enclosure. If a cable in the loop faults, the faulted cable is pulled "parked" parked at each end, and the working cables are reconfigured to supply power to all of the transformers in the loop. This is normal done with pad mount transformers and load break elbow terminations on the cables.
Don
