JFletcher
- Williamsburg, VA
Was doing a LV landscaping lighting system Friday, and was thinking about voltage drop as the runs were fairly long. I was thinking also that running the cable in a loop back to the driver might be a way to reduce VD. Example: you have 15 10W 12VDC landscape lights that use 300' of cable. Say the last light is 20' from the driver; could you run from that light 20' back to the driver to effectively have 160' of run vs 320'? Would this be an NEC violation? Would this be a violation with a string of 120V receptacles? What about interconnected smoke alarms?
Ive heard this was done years ago in communications to improve reliability - if you had an open pair on one end, your system would still work because it was a complete circuit from the other. I'm not talking about using two drivers or breakers to feed one circuit, but a circuit that is complete in a circle-like pattern.
