HO called and said his light and power saw is not working. Well when I got he said he replaced the main breaker because the PUCO said that everything is OK on their end. Well I check the volts at the main 240 and 120 to neutral, at this time I had all the breakers off. When I turn on one breaker the voltage drop to 50v. Turn breaker off again and checked in-coming power 240/120. I pulled the meter and checked in-coming 240/120. What I did not do was put a load on at the meter to see if I get half voltage there. Any suggestions on what to check next.
