On the 220v circuit one leg reads 120v and the other reads ov at the subpanel. Both legs read 120v v at the main panel. The panel has a separate ground wire connected to a ground at the subpanel. I used the green wire (4 gauge) as a test lead and connect it to the main and subpanel and now have 120v on both lines and all circuits are working. The line that is disconnected and capped at both ends reads 80v. How can this be?
