Loss one leg of a 300' AL 2,2,2,4, 220v line, buried in electrical conduit.
VWM
Osyka, MS
Retired
On the 220v circuit one leg reads 120v and the other reads ov at the subpanel. Both legs read 120v v at the main panel. The panel has a separate ground wire connected to a ground at the subpanel. I used the green wire (4 gauge) as a test lead and connect it to the main and subpanel and now have 120v on both lines and all circuits are working. The line that is disconnected and capped at both ends reads 80v. How can this be?
Sounds like it's burnt in to. I find this every now and then in areas that have been flooded.
Probably capacitive coupling. Did you read that with a standard DMM or a low impedance meter? If you don't have a low impedance meter connect a load to it that then check voltage again, if it is zero it is capacitive coupling. If there is still voltage your swapped line maybe also damaged and some leakage is occurring between conductors at the damaged area. Not uncommon at all to see this with damaged underground aluminum in my experiences. A small hole in conductor insulation is all it takes to start this, it may take time for it to fail, soil moisture does factor in how long this may take. Once the conductor has oxidized enough cross section away, the smaller remaining cross section has to carry all the load and heats up. That does help accelerate further oxidation. Insulation on an adjacent conductor may be damaged by the heat and now you start having deterioration of the adjacent conductor.
Yes i connected the green wire in place of the burnt wire as a test. And yes i wil replace the green with a 4 gauge black wire. I realize that I need return the green wire to the main panel as a ground return even though I have a case ground and the sub panel is not bonded. Do you have any idea what might have caused this issue?
Retired from Air Force
The forum rues do not allow us to assist with DIY projects, you can try diychatroom.com.
This site is designed for:
  • Electrical Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
* This NEC� Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
