djeiermann
New member
- Bay Shore, NY
Can anyone help.....I've encountered this problem on
2 seperate occasions....how do I fix this problem
Trace the neutral from box to box. Start at the midpoint if you know the route the wires follow.
Look carefully at backstabbed feed through wiring, since it may turn good when you pull the device out of the box.
Tapatalk!
Use of a low impedance meter takes away most of the confusion.I remember it is confusing to use volt meter when looking for open neutral. I used a pigtail and light bulb to test wiring for open or present neutral.
