- Massachusetts
:lol::lol::lol:
If the disconnect switch is locked in the closed (ON) position how can you open it? ...
I've seen it where a business will lock a disconnect on the exterior of a building. ....
... I would not lockout a breaker in the closed position, ...
Locking out breakers in the closed position is done all the time in industrial maintenance. ...
I am not clear about what sort of maintenance would require locking a breaker closed.
Truly priceless
:rotflmao::rotflmao::rotflmao:
Here is the part that makes me pretty sure he is not locking disconnect on.OP does not necessarily say he is locking the disconnect in the ON position. That is a possibility though and has been part of what some have been talking about.
I am in need of qualified opinions as I have a problem. I have been told that it is ok to install a padlock on an energized disconnect. I have been reassured that the disconnect can be turned off with the said lock in place. The customer's safety personnel (large auto company) also said it was ok. I have been in the trade 37 years and never had someone tell me it was ok. The reason being is the OEM doesn't want to lose his lock.
Any comments? Yeah I know you can't fix stupid, but...
Something about this is all wrong. I know of no disconnect switch that, if locked in EITHER position, can still be changed! .
... If OP just wants a place to store the lock and the switch can still be turned off - so what. ...
Whoa - two that actually read the OP. All right.Here is the part that makes me pretty sure he is not locking disconnect on.
And one more that didn't.Something about this is all wrong. I know of no disconnect switch that, if locked in EITHER position, can still be changed! ....
And one still trying to herd the cats.This one and others like it can be
When the switch is in the on position you can lock the lock in the 'off' hole and still operate the switch normally.
Yeah, I see it now. I mistyped my thoughts: locking out breakers in the open (de energized) position is done all the time. I have seen valves locked open/shut, but never a breaker in the energized position.
