ptonsparky
Tom
- EC - retired
I was called yesterday to replace a starter in a bucket on a MCC. After I was there a few minutes I began to see why I was called in. The night crew was not around to question so I don't know the sequence of events.
To make it short, after the fault they had numerous small smoldering fires caused by the arcing and sparking of the raceways in the area of the MCC. Dust is present but it is not considered hazardous. The fault was in a bucket of the MCC. (blew out the side of a 15 amp MCP and tripped the main.) 480/277 and is not supposed to have any neutral load. I do know the grounded conductor, neutral, for this underground service was "added" and is not in the same raceways as the SE conductors. Most likely undersized.
Operators had mentioned seeing sparks along various metal contact points in the past, at times of faults.
The only way I can see this happening is if the the grounded conductor to this service entrance equipment is broken entirely and current is trying to find a path via raceways, and equipment to one of the other services. Could this be a result of the undersized separated neutral?
