Ryan Currin
- Allston MA
I have a circuit in an underground raceway feeding a GFCI outlet under a gas burner station in a restaurant. We now have to install low voltage heat detectors under these units that are connected to a fire suppression control panel. The relay output on the detector is 24 volts and will then shut down power to the GFCI under alarm conditions. Is this low voltage circuit considered class 2? I believe it is class 1 because it is a signaling circuit, and the powered equipment is functionally associated with all the circuits. If all these conductors have an equal insulation rating, can I install them in the same conduit?
