Good morning,recently I was sent to a church to repair a lighting problem. The in house maintenance guy decided to add a set of 3 ways to the church main hall,He took a relay with 24 volt coil ran the line and load thru it ran to sets of fire alarm cable to the other end of the church by a door.
,one end goes thru a wiremold race way thru a fire alarm pull station then to a wiremold box with the other end of the 3 way that he added.
Then he ran the other set down a conduit with 110 voltage to a 3 gang switch box and placed his 2nd 3 way with them.
My quetion is can low voltage and fire alarm cables share the same raceway? I do not own a copy of NFPA 72 {will soon}Thank you p.s.lites didn,t work either,I Blessed myself and left
