The specs have an asterisk on the 100kw rating. But no footnotes are to be found.
I think it means 100 kw at 480, derated for 240 and 208The specs have an asterisk on the 100kw rating. But no footnotes are to be found.
Something that small is surely not designed to dissipate 100kW???
At 0.06 cents per KWH, I came up with about $52,000 per year to run that load bank.
Probably a good thing it blew up.
Also, 511 volts is only about 6% high. That would increase the power about 12%. But shouldn't the voltage have dropped back down to a nominal 480V, since that was the whole idea?
I believe the diesel locomotives have large resistor banks for braking of the DC traction motors...
Infinity, what is the actual use of that heater? As a space heater on steroids, I guess it would have a use, I don't see any application where using it as a load bank would be a good idea, aside from testing purposes.
I believe the diesel locomotives have large resistor banks for braking of the DC traction motors... I just don't see the application for what you have pictured.
What kind of connector is being used for the plug-and receptacle configuration?
And contrary to the earlier statement, they do play a role in braking on sustained downgrades.Those are E1016 Camloks.
Re diesel locomotives- their breaking resistors are usually on the roof with whackin' huge fans underneath.
Infinity, look at the bright side. Someone else paid to prove the integrity of your work.
If only you had done a subpar job, the voltage would have sagged, and that joke of a load bank would have lived another day. Shame on you, do you feel guilty
Should I say this falls under no good deed goes unpaid?
And I complain about my idiot bosses that don’t understand basic concepts.
DC traction motors are almost obsolete.
https://www.progressrail.com/en/rol...ely. But there’s a ton of old ones out there.
