- Tennessee NEC:2017
- Semi-Retired Electrician
I am doing a kitchen remodel and due to wiring access problems I'm using Caseta wireless switches with Pico remotes. I've used these many many times with no problems. But I think this is the first time I have used multiple Casetas together in ganged boxes. I have 11 LED recessed lights on Caseta #1 and two LED lights on Caseta #2. Both in a 3-gang box. The Picos are also ganged at the other end
For those not familiar with how these work, the Caseta wireless replaces a mechanical switch and you place the Pico remote at desired location. Just a way to make a 3-way switch circuit without the wiring between switches. You put the Caseta into program mode then go to the Pico and put it in program mode, then the units pair up and lights can be controlled from each location.
The problem I'm having is when I program/pair Caseta #1 the lights turn on/off as they should. When #2 is program/paired they also work as expected.
Then suddenly Caseta #1 switch turns off/on all lights, including those controlled by the Caseta #2. Then Caseta #2 doesn't do anything.
So I start all over and each switch works as expected, then after a while, the problem returns.
I think I program/paired these 3 times, they were working correctly when I left but don't know if they will remain that way.
Only thing I noticed is there is a slight flicker on the switch that controls only the two lights. I think I'm going to have to add the MLC (minimum load capacitor) as the two lights don't have enough load for the Caseta. Could this have any bearing on why one switch looses programming and the other takes over for all the lights?
