jmoschetti45
- Michigan
Currently upgrading some lutron 3-way dimmer setups, and thought of something. Per lutron, you can have basically a 4 to 9 way setup, as long as you use 1 master and X companion dimmers. Great, but not what I want/need.
If you've ever worked with these, you know they have black, brass, and blue terminals. From a quick call to lutron and some thinking, the blue which is daisy chained from each switch is a constant hot. Makes sense since they all need power to work.
Now, you can use a master dimmer and regular 3-way (or technically 1-way) switch to make a 3-way. Great.
I'm in need of a master dimmer, companion dimmer, and a regular switch (this other switch is actually relays for automation). Per the lutron book, you put the master and companion at the 3-way ends like in a regular 3-way lutron setup, and in the 4-way spot you tie the 2 (lets call them "out" side) of the travelers together (which become the blue connection - always hot), and the remaining 2 connections from the travelers go to the other 2 screws.
Part of me wants to assume this is now basically a 3 way....since its switching either the black or brass from the master and companion dimmer into the blue leg.
Anybody ever tried this? I'm going to rig up a bench setup worst case and try it out, just wondering if it's been done.
Absolute last resort is to pop apart a companion dimmer and replace the internal switch with some automation, but I'm trying to avoid buying a dozen or more of these just for that.
