ELA
- Electrical Test Engineer
Thanks for your test data Little Bill,
I was most interested in the 80 ma when the loads are off to see that it was something somewhat significant as compared to Microamps which would make it more susceptible to interference.
Where are the voltage readings taken? It would also be interesting to know how much voltage is dropped across the transmitter itself when no loads are on.
These readings may be of some use to you, as a baseline to compare against, if you then take the same readings at the customer location.
Based on the 80ma reading I would no longer suggest adding an additional "dummy" load at the canopy.
Do you have a neutral in the box where the transmitter is? If so then the capacitor idea in that box might be a good first attempt.
