LarryFine
- Henrico County, VA
- Electrical Contractor
I haven't used a Magnepull, but the only advantage I see over any other magnet/chain combination is the attraction between the puller and the bullet should be stronger, if the bullet is also magnetic.
What they don't show you is how to drag a cable towards a drilled plate, when you want to feed the cablke into the wall and out the attic. You can bring the bullet to the top of the wall, but then what?
Of course, one could always pull in a pull string to reverse the direction of the pull.
