The prototypes has been built and tested. My only concern is that the since the female magnetic connectors will be located at fixed locations and the node that is always energized. It stays somewhat exposed until the male connector makes a contact with it to send the current through the tube......will it be in issue with UL? I have seen many power rails by electronic companies that are using this technology in power rails. Power rail has energized components exposed but since it low voltage, it wont cause an electric shock in case of a human contact but as soon as you place an LED strip on to the power rail housed by a magnet, it forces the LED strip to keep in tact and lights up the LED Strip.
