Has anyone ran into this? The main breaker is tripping on a 200 amp residential panel every once in a while. The home owner says it seems to only happen when they leave the house for a week or so for vacation in the winter and then come back. They have an electric heat pump system with (2) outdoor compressors. They say they leave the temp. at about 65 when they are away and when they come home, they turn it up to 70 or so and when the auxiliary heat kicks in, it trips the main. They did say it even happened once just when they went out to eat and came home and upped the temp a little. I clamped A phase of the main and it was drawing 30 amps and I clamped the B phase and it was drawing 40 amps (under normal conditions with the heat running). I did notice however, that while it was clamped, the A phase went up to 90 amps for a couple of seconds and then went back down to 30. I figured this was some sort of in - rush?
I'm thinking possibly a faulty main breaker (Cutler - Hammer)? Or maybe the main can be replaced with one that has some sort of settings that could be adjusted for in-rush?
Thanks
Thanks
