kwired
Electron manager
- NE Nebraska
- EC
But do you take photo of every device you connect or other similar finer details that would result in so much documentation that it possibly becomes a bigger job to organize the documentation then the installs being done?My point was, if I have records of the work I perform, then if someone else later does some work after me, I can show what I did and what I did not do. That way it's not a he-said/she-said situation where somebody is blaming me for landing a hot wire on a ground terminal.
In the OP's situation, there appears to be some dispute as to who was responsible for doing improper work. If the OP has accurate documentation of all his work (including photos), then clearly he can't be blamed for doing improper work by others.
Some occasional notes on items that peak your interest when you encounter them is one thing, documenting every single detail is another.
I do like this idea or something similar:
There are often times when we find some thing above a cieling or other places that are not compliant. I have found it valuable to state it on my invoice along with a price to fix it. This often makes an additional sale, and if it doesnt, then I have it documented that we brought it up and it was turned down. A good example of this was just on a residential service call, we pointed out that the sump pump was sharing a circuit with a freezer and lighting. The customer gave the usual " been that way for years, its ok". Well, about two years later the circuit tripped and the sump overflowed. Customer asked me why we didn't tell them this was the case? I certainly didn't remember and thought I owed an apology, then the secretary looked up the paperwork and it was very well stated as well as priced out the solution. When I showed this to the customer, they remembered also and felt just a little ashamed. Built credibility on our end . It is so easy to just verbally notify them, but no one remembers that later. I am also surprised how often I will get a call maybe a year later and the customer has decided to go ahead with the repair we suggested.
