Alwayslearningelec
- NJ
- Estimator
If there is a existing fire alarm system that is being replaced with a new what is involved if you have to maintain the existing until the new is up and online? Thanks.
We have done some where did a zone at a time. We would take a zone out of service and convert to the new system. All work had to be completed for that zone by the end of the day. Relays were added to permit the old and new systems to "talk" to each other. An alarm in either system would cause all of the indicating devices in both systems to operate. We were not required to provide a fire watch, however if we had failed to compete a zone in the work day, an overnight fire watch would have been required.
That is how we have done it, in the high rise jobs.
This is an active psych center. You would have to carry a fire watch 24 hrs a day? No? Can't you just install the new devices( about 350), wiring etc then kind of bring down the old then bring up the new so there is not much down time? Thanks
In high rises we cannot shutdown areas without a firewatch, day or night.
If your municipality uses the International Fire Code 2009 here is the apprpriate section.
901.7 Systems out of service. Where a required fire protection system is out of service, the fire department and the fire code official shall be notified immediately and, where required by the fire code official, the building shall either be evacuated or an approved fire watch shall be provided for all occupants left unprotected by the shutdown until the fire protection system has been returned to service.
Where utilized, fire watches shall be provided with at least one approved means for notification of the fire department and their only duty shall be to perform constant patrols of the protected premises and keep watch for fires.
Ok, so if the complete exisitong system is being replaced by a new the extg can stay until the new is in an online then the old can come our. Is that one option? Also, does all the fa wire have to come our or can in be left up in the ceiling? Thanks
But to do that fully you would need to place the devices in new locations while the old are in use. Then when you remove the old there may be some aesthetic criticism. Not the best option, but maybe accepted.
If you can remove the old cables, you have to 760.25.
