maintenance man
- paoli, pa
If working above in a lift and working near energized lines I understand about keeping a safe working distance away. Should some type of grounding to the lift be employed before work begins ? This could be inside or outside work. I would use the ground grid outside or building frame inside . Is this a exceptable means ?
