al hildenbrand
- Minnesota
- Electrical Contractor, Electrical Consultant, Electrical Engineer
Re: Making a 3 way switch a 4 way
Good night JW,
While your description
What we are talking about, is when the conductors of the same circuit are in different NM cables as allowed by 300.3(B)(3).
300.3(B)(3) is not exclusively about cables with only one conductor in them, . . . it is also about cables with multiple conductors of which at least one conductor is part of a circuit that is also running in another cable.
Good night JW,
is absolutely correct when the conductors of the same circuit at present in the NM cable that we are not talking about.If it was a three way three wire dead end switch current would be going and coming in same cable or two conductors hot at the same time. If it was fed through then the neutral would be present for the return current.
