TJC
- New Jersey
Utility makes it mandatory to have a service disconnect before their CT cabinet. Grounded conductor (neutral) is bonded to GEC and enclosure in the disconnect. Disconnect then feeds into Utility CT cabinet which then feeds into a main lug MDP. I now pick up the job from the MDP into the sub panels. I noticed that in the CT and MDP the grounded conductor(neutral) is bonded to the enclosure. I brought this up to the inspector thinking that this would create objectionable current considering both the CT and MDP are downstream from the service disconnect but I was told that it was fine. Can someone clarify if this is allowed bc of some Utility loophole or if I'm just downright wrong? Thanks
