Why would you want to install an extension cord type application on a hot water heater? Is this heater being moved around on a daily basis or what? Doesnt make sense. All the hot water heaters I've seen are fixed in place.
Extension cord? Just a cord and plug application like washing machine. It's just that it is not the right way to do it per NEC. I guess some local cord enforcement allow it, like here in Shelby county.
I never understood Shelby county as in the way things are allowed and accepted to be done, but yet I have learned from this forum that I was comitting a code violation per NEC.
Water heaters are allowed to have a cord and plug for the means of diconnect.
Furnace units are allowed to be done the same way.
We are allowed NM outdoors in conduit.
Our 8' ground rods are to be a few inches above ground with an exposed ground clamp.
I can use a Murray breaker in a Cutler Hammer panel and it will pass inspection.
An island in a kitchen does not require a receptacle.
There are others I cant think of at the moment.
This forum has shown me that I have been violating the NEC code per acceptable practices permitted by my AHJ.
I have always been wanting to be able to go by the book and not have to wonder if something is OK or not with my AHJ.
Im going down to south central Texas this weekend to start work due to the fact the Memphis economy has gone down enough to not have any work to make a living. I hope down in Texas the NEC is followed as it should be.
BTW. Tennessee has gone to the 2008 NEC cycle, but Shelby county will continue under the 2002 for atleast another year.
