Masters License and TECL
David Legate
Montgomery, Tx.
Master Electrician
Question...
Can an Electrical company have two Masters registered under the same TECL#?
Our existing master is going to be phasing out, and we are wanting to go ahead and register our new one so there is no lapse.
Question...
Possibly/probably, depends on the laws of your state.
Good luck!
Ron
In NC large companies had many qualifiers, they were employed by the companies and were normally officers, as in vice presidents, secretaries, PM'S, etc ....
Question...
Try Texas department of licensening and regulation
Thanks for the replies. I've seen the info on, "a master can only be assigned to one TECL unless he owns 50% or more of the other, then he can be assigned to two", but i can't find anything on whether a company can have two registered masters under one TECL#.
Looks like you have 30 days after he leaves.
Electricians
Apply for a New Electrical Contractor License
On this page:
Master Electrician of Record
Insurance Requirements
Application and Fee
Applicants with Criminal Convictions
Electrical contractors are licensed to engage in the business of designing, installing, erecting, repairing, or altering electrical wires or conductors to be used for light, heat, power, or signaling purposes.
This includes the installation or repair of ducts, raceways, or conduits for the reception or protection of wires or conductors and the installation or repair of any electrical machinery, apparatus, or system used for electrical light, heat, power, or signaling.
You must employ a licensed Master Electrician to apply for an Electrical Contractor license. The Master Electrician may also be the business owner.
A Master Electrician may only be assigned to a single Electrical Contractor, unless the Master Electrician owns more than 50 percent of the electrical contracting business.
Changing Your Master Electrician of Record
When your Master Electrician of record leaves employment with your business, you must notify the department and designate a new Master Electrician of record within thirty business days from the date of separation.
You may submit this notification by mail on an Electrical Contractor Notice of Change.
