Max length of liquidtight feeding a rooftop
laramie
Hey all,
Thanks in advance for the help..
I'm feeding a 3 phase 208 rooftop unit, and the closest junction box with 208 is about 15 feet away...
I'd like to run 3/4" Sealtite from the disconnect on the roof to the junction box, but am unsure what article lists the max length of liquidtight i can use.
I remember a certain article that states if the liquidtight is over 6', it needs a separate grounding wire, which is fine, but can't find the rest..
Re: Max length of liquidtight feeding a rooftop
Check out article 350.
The length restrictions you are thinking about are for LFNC, see 356.10(5) & 356.12 (3).
Chris
Why not use non-metallic liquidtight instead? If it's in the specs, fine, but if it's not, I wouldn't use the stuff if it were free. It has a nasty habit of rusting out.
Secure it like it is regular conduit.350.30 A & B
allows it to be run as far as you want.The 6 ft part pertains to a whip from disc. to equiptment.
