If a service panel which has a single service disconnect for a sfd is located on a pole, and there is 1 overcurrent device which supplys a feeder to a panel for a seperate structure, does the subpanel need a single disconnect, or can up to 6 breakers in the subpanel serve as a disconnecting means? I have been under the impression that if there are up to 6 breakers at the subpanel that this acts as the disconnecting means, however one of my co workers believes that the "up to 6 breakers" is refering to other feeders and that a main disconnect is required so that the subpanel ungrounded busbar is disconnected. Check the 2001 CEC section 225-31,32,33,and 34. What do you think? Thank you.
