What is the difference between maximum water level and normal water level?
So would a pool with a water level of 42 inches at the skimmer (normal operating level) and maximumn water level to the top edge was at 46 inches this would not be considered a storable pool even if it had inflatable walls????
Storable Swimming, Wading, or Immersion Pool. Those that are constructed on or above the ground and are capable of holding water to a maximum depth of 1.0 m (42 in.), or a pool with nonmetallic, molded polymeric walls or inflatable fabric walls regardless of dimension.
Pool skimmers are normally 8" high where is the normal water level? top, bottom or middle of the skimmer. Why not just use max. water level for all issues?
If the pool is capable of holding water to 46" then I would not call it a storable pool.
Dennis, Am I reading it wrong ?
with the "or" in there, would a inflatable wall pool not be considered storable regardless of the depth (a dimension). I'm unsure if they make such an animal..just asking
The middle.Pool skimmers are normally 8" high where is the normal water level? top, bottom or middle of the skimmer.
