jumper
- 3 Hr 2 Min from Winged Horses
if we had a gun in this thread, we could at least put it out of it's misery.
I am not allowed to play with guns. Makes people nervous for some reason...
the slope must be of the same sign
they are not
Well, that's one choice of the meaning of "in phase". Another choice is not to require that.
The definitions of "phase" and "in phase" obviously should be a consensus choice. But if I were in charge, then in the context of sine waves of a fixed frequency, I would define a phase as a one-dimensional vector space of such functions. That would correspond to the usual usage of single phase, two phase, and three phase systems (with the exception of calling two hots and a neutral from a 3 phase wye system "single phase").
Cheers, Wayne
if you don't require that they are out of phase
To those saying a 120/240 service is two phases, I'd like to ask: how many phases is a high-leg delta?
Three.How many do you want to it be?![]()
Three.![]()
You do not see six? or more?
Dan, wouldn't the other two primaries now be connected in series across the two still-hot primary phases, i.e., in parallel with the still-fully-energized primary? Wouldn't they now each see half of their original line-to-line voltage, and create two 60-volt sources? Of course, there would no longer be a phase difference, but wouldn't there now be 120, 60, 60?Now drop any one leg at the primary. Primary side voltages across the winding become x 0 0.
Only one phase will remain with a voltage that will power a winding. Now the transformer is in its single phase condition.
Load side voltages are 120 0 0 on the three conductors. It can be single phased, but the complaints will not stop until more than one phase is available at the primary.
Good question. The 2-ph guys would insist on keeping the 'scope - probe on the neutral, and see A-N as -180 deg., B-N as (I'm not sure; 120? 0?), and C-N as +180 deg.To those saying a 120/240 service is two phases, I'd like to ask: how many phases is a high-leg delta?
I see more than three voltage waveforms, but not more than three electrical 'phases'.![]()
By the way, I just got off the phone with my E.E. friend, and we spoke at length about this topic. He immediately said that this is a polarity matter, not a phase matter. I explained the insistence of the 'scope - probe on the neutral, and he agreed it's a choice of measurement method. (Forget earthing the neutral for the moment.) Swapping 'scope leads changes polarity, not phase angle.
I would connect it A-B, B-C, and C-A, and see three equal and in-sequence phases.
Aha! You said polarity!Our assigned reference, the neutral, designates the polarity we give it for analysis.
Which, in a 1ph system, merely resembles two opposing phase angles.We take our phase angle from that reference point.
Please define the six.Three phase and single phase. Six signals.
That's what I'm trying to get you engineers to do! Seems it's not simple, no one can just quote a book.Define phase.
Last time I checked it was a mathematical expression.
Phase angle between conductors perhaps...
Our assigned reference, the neutral, designates the polarity we give it for analysis. We take our phase angle from that reference point.
